these are the features listed for the regular rp-6 and the limited edition yellow ones. which one is best?
KRK Rokit Powered 6 Generation 2 Studio Monitor Limited Edition Glossy Yellow Features:
Radically Curved Front Baffle Design
High Frequency Waveguide
High Frequency Level control
Input Gain Control
Multiple Input Options
Front-Firing Port
Recessed Tweeter Waveguide
Bi-Amplified Design with Active Crossover
Rigid Wood Cabinet
New KRK Proprietary Woofers and Tweeters
KRK Rokit Powered 6 Generation 2 Studio Monitor Limited Edition Glossy Yellow Specifications:
Woofer: 6-inch Glass Aramid Composite Woofer
Tweeter: 1-inch Neodymium Soft Dome Tweeter with Ferro Fluid
Input: XLR, RCA & 1/4-inch TRS - 10k Ohm, Balanced / Unbalanced
Amplification: 100 Watt Bi-amp Dynamic Power, 24 dB Octave Filters
Frequency Response: 49Hz - 20kHz
Video Shielding: Yes
Dimensions (H x W x D): 12-11/16" x 8-7/8" x 11-1/2"
KRK Rokit Powered 6 Generation 2 Studio Monitor Features:
Radically curved front plate design virtually eliminates diffraction distortion
Waveguide design provides amazing detail and imaging
Front-firing port provides low freq extension without boundary coupling
New speaker voicing for even more accurate frequency response
1" Neodymium soft dome tweeter
Glass Aramid Composite Cone Woofer
KRK Rokit Powered 6 Generation 2 Studio Monitor Specifications:
Woofer: 6" Glass Aramid Composite Woofer
Tweeter: 1" Neodymium Soft Dome Tweeter with Ferro Fluid
Input: XLR (3-pin), RCA & 1/4" TRS - 10k Ohm, Balanced / Unbalanced
Amplification: 100 Watt Dynamic Power Bi-amp, 24 dB Octave Filters
Freq Response: 49Hz - 20kHz
Peak SPL 106dB
Dimensions (H x W x D): 12 11/16" x 8 7/8" x 11 1/2", 32.1cm x 22.5cm x 29 cm
Shipping Weight: 23 lbs (11 Kg)
