Noise on Delta 1010LT
  • Thread starter Thread starter spankenstein
spankenstein
Input 3 on my M-Audio Delta 1010LT is making strange noises once it's recorded. Sort of a weird robotic sounding effect to it. This is not present when listening through the monitor mixer but is when recorded through SONAR.
I switched out cables, pres and mics and the only consistent item is input 3. I checked the cable and it's tight to the card.
hmmmm. Assuming your not somehow doubling the signal it sounds like something broke. Does it sound like it's phasing?
If you're sure all your routing is correct then you may need to take it back or get repaired. Could be a bad ADC.
It's like distortion. I'll try to make a clip tonight.
I won't make a clip because it's gone. I reloaded and everything is fine now.
