no playback in wave mode
  • Thread starter Thread starter Foo-bu
F
Foo-bu
whenever im in the wave editing mode it doesnt let me hear any playback. it really sucks especially when im adding an effect on it. whenever im in multitrack mode it works perfect. any advice for how to fix this?
go to device settings and make sure you have selected your playback device to work as default in edit mode
Man, Im having the same problem... it just aint working for me either. But, it seems to only happen when working with something in Multitrack mode; if you have nothing in Multitrack mode going on, then it can play back in Edit Mode. I never had this problem till I purchased this new Audiophile 2496 soundcard. Whats up people? Help please!
yeah it stoped working for me after i bought my new delta 44
Ok, mine works so far since i went to "Device Order"; and told CEP to use my device for "EV", which was not selected at first. Its playing in EV now since I did so, so hopefully it stays this way. If you figure out something Foo-bu, let me know, as I will do the same. Peace!
That's what I ment when I said you had to select the device for default in edit mode.
Good to see it works
Tukkis:D
or..
set the WAVE MAPPER in device props/order to use in Edit mode
now you will use your windows standard output card, which can be switched by clicking the little speaker icon in your taskbar.
