wavestar
Student of life
In this Manual here
On page 12, I don't understand the last two bypass modes. the 0% Mix makes sense, it's basically a pass though. But as far as the FX input and FX Output, I'm just not getting it.
FX Input
Shuts off the Engine Input in order to let the
effect "ring out", but leaves the same amount
of dry signal through the unit.
FX Output
Shuts off the Engine Output in order to kill the
FX instantaneously, but leave the same
amount of dry signal coming through
On the FX input, if you're shutting off the input, how is there going to be an effect to output? Or is this a matter of what left in the buffer? is that so you can hear the effect when you stop the input? The FX Output makes more sense, but then it sort of sounds like the 0% bypass option.
FX Input
FX Output
