ports are showing up, but all inactive at this point. Is that correct since I don't have any tracks up uet?
2012-08-09_1159 - Sluggo42's library
F4 is the shortcut key to VST Connections. Click the 'input' tab, then add bus. Choose Mono, select input 1 from the Tascam. Then create a track in cubase, Project>Add Track>Audio>Mono. You should be able to record. Make sure to press the monitor icon on the track (looks like a side pic of a speaker), as well as the record enable button (red target thingy).
You should be good to go.![]()
2012-08-09_1205 - Sluggo42's library so far, now making a mono track
ok, but it's not making any sound on playback, but I DO HAVE A WAVE !!!!
I wonder why it's not making sound on playback...
My good man, I would like to kiss you right now!
But, since that's gay and I'm not, perhaps I cold buy you a tall cold beer??
I am SOOOOOO HAPPY right now. You have solved HOUrS and HOURs of angst for me. Seriously, if you are ever in so cal, you have a free guide service bass fishing day at your request. Tha'ts all I really can offer other that a drum lesson, but you probably already know better drummers than me, and that beer is available too.
YOU DA MAN!!!![]()
It is probably just low output from your guitar. I typically run direct through a preamp first to raise the gain. With LE, you don't have an input level mixer, so try this. Insert VSTDynamics in the first slot, turn the Threshold to 0, click off 'auto' under Make Up Gain, and raise your level there, previous to your guitar sim.
What level are you getting into Cubase? -18dbfs is your ideal input level. That is vaguely the digital equivalent to 0db in the analog realm. Though digital recording has the headroom to go hotter, most plugins are designed to operate best around this level. There is much discussion about this around here, but that is a good place to aim for.
Man, I would love to retire with a boat!![]()
