but still nothing is working,Yep!! You got it!![]()
When I select us1800, and then go to the control panel, I only get tascam's fron page, or this:
2012-08-09_1119 - Sluggo42's library
oh snap
now the whole stupid thing just crashed, and I have to restart it.... grrrrrrrr
What isn't working? Did you make the 1800 your default sound device in Windows? That is how you would hear Media Player, Youtube, whatever. The Release Driver option allows Windows to use the 1800, even when Cubase is.
Your next step will be to create input bus's via VST Connections under Devices. Then, on an audio track, you will select input bus via the Inspector to the left of the project screen. This is where the Getting Started documentation can really help.
ok, I restarted and have a blank project up, I am going to open un a mono track, to try to get a mic 1 signal only for starters
ok, doing that nowYeah, I know how frustrating it can be. It is absolutely the 1800 drivers that you want to use. There are no issues with them.
Ok, let's backtrack first. Go HERE and make sure you have the correct driver installed for your computer (32 or 64 bit)
here is where I sit so far
2012-08-09_1131 - Sluggo42's library
ok, doing that now
FAIL
2012-08-09_1144 - Sluggo42's library
I got the same message when I tried to load off the original disk.
However, I did load the driver from the disc as specifically directed to the first time..
Say, I bet it won't load cuz the USB cable is hooked up. But when I did it the first time, it wasn't until it told me to do so... I'll try that again
