R
riotshield
Hi,
I just 'upgraded' from using an audio-only multitracker (CEP) to Sonar 2.2. This is my first time using MIDI, I think. Basically I would like to add some synth sounds to my recordings (downloaded Triangle II). So I have my Evolution MK-249C connected, fire up Sonar, insert Triangle, and it plays. But I'm confused as to actually record what I'm playing. I'm guessing I arm a MIDI track for recording and record that, and when I downmix it will add the audio? Also there are multiple options under Ins and Outs under each track and I don't know which one to pick.
Also, is there any way to see what I'm playing when I'm recording? i.e., in CEP I could see the waveforms being drawn as it was recording which was helpful. But I can't see anything until after I hit Stop.
Last, what is a good latency for MIDI? I am using a USB interface and with 384 samples on my Audiophile 2496 and ASIO drivers it says it is 8 ms. Is this decent? When I set the samples lower sometimes I will hear pops/clicks in my audio.
Thanks!
Thanks!
What outputs to use depends on the synth, so there's no real good answer for that one. I just use the "Make tracks automaticly" when I add a DXi in Sonar, and if I need more output-audiotracks, I just make them myself.
