			RICK FITZPATRICK
Hello everyone. God do I love analog. You HAVE to if you use it. Tonight my best friend came over for our weekly traditional laugh, listen, practice, and fool around with analog sessions. We had a ball.  Since he had brought a new 1/2" 456, after our practice(I say that loosly), we decided that we have one reel striped already, so we figured we would go ahead and stripe the new tape on my #1 MSR-16 for TC playback on #2 MSR-16 when I finish cabling #2 later. This way the tape will be ready. Ok, all of a sudden a question came to mind. Heres the first one:
Can you record timecode onto a tape, recording it on a machine that is NOT going to be the machine that will ultimately read it? In other words, when I put this tape on the second MSR later, will it play the TC correctly, even though it was recorded on my #1 machine?(#1 is master, #2 will be slave)(later, all midi stuff will slave also)
I thread tape. Run 30 sec leader I set tape counter to 000, and advance tape one minute. I start TC record sequence, and hiting record/play, I let it run, midizer is generating TC. After about 5 minutes, I realize that the bar meter on trk 16 isn't showing anything. ARRGGGGGRR. I stop. Hmmm. What a moron. I had forgot to arm the track. Ok, live and learn. Now what to do. Ok, I think I'll ......opps,
Second question.:
At this point , how do I now return the dispay to the TC default which is 00(Hr) 59(min)30(sec)? (This gives a 30 second run before 00 00 00) It ran to 01(hr)07(min)06(sec).
I decide to rtz which is before time code started.. I hit play. Runs 1 min and....Holy cow, the display shows TC running! Hmmmm. How can this be? The display shows the time code advancing even though the track wasn't armed. Ok, what gives? Not only that, I thought smpte was in real hrs, min, seconds(and frames also)Well, the machine ran apprx 5 real minutes. How could it have possibly went past 1 hr on the display?
Now I am perplexed. I decide to leave this TC sequence in place, and advance the tape for a minute or two and try this again. Hmmm. Better turn off midizer to reset TC display to default. It works. This time I arm the trk, and start the TC record sequence again, this time making sure that the bar meter is registering the signal. It is. Which is a steady 0db(u?), I assume because its TC. I record TC to the end of tape. Manual says exit, rewind, check display button for TC. Its on. I stop Now manual says "Set up" for synch must be performed for the midiizer to learn "charachteristics" of transports. I perform "set up" even though I only have the master connected. It completes set up. I rtz to beginning of the tape. Crap. I realize I am at the beginning of first TC attempt. Damn. I love analog but SHEEEEEEZ its tough being an amateur. Well, HR.com time again!!!!
... I KNOW, I KNOW,....."what the hell did he ask"?....hell, even asking questions is confusing!!!
Doggon, this is LOOOOOOONG already, and I've only got 2 questions posted and had 10 (hey, gotta have some fun here too
 (hey, gotta have some fun here too )  thanks guys!
)  thanks guys!
fitz
Second question.:
)  thanks guys!fitz
		 ) so its hard to remember everything. Besides, some things are real vague in the manual. Like I said, I love analog, but it sucks being an amateur!
  I didn't know how you refered to your "tape decks". I look stupid enough most of the time, and try to avoid it if possible.
