D
drrats
Hi everyone, this is my first post on these forums. So much good info here! Looking forward to learning and contributing if I do decide to go down the analog path!
I am hoping to put together an analog setup that is portable. I think I've read most post on here re. the Tascams in an attempt to grasp the realities of this idea.
So I already have a Tascam m216 which we use as part of our P.A in our band room. It's small and fits well with my portability idea and has nice VU meters for the 4 output mix busses. I've been on the lookout for a good tape machine to match it. I know the m216 has both unbalanced outs as inserts (-10db correct?) and balanced outs on the 4 busses (+4db correct), so depending on whether I was tracking 4 or 8 microphones (use the busses for 4 outs or the inserts for 8 outs) the tascam 48ob would give me better options in this regard right? Can you track both balanced and unbalanced signals simultaneously (4 channels from the bus and another 4 outs using the inserts)?
The machine I have found has heads that are in great condition (I'm not that experienced but used the advice in this thread to evaluate the deck... https://homerecording.com/bbs/gener...and-gear/tascam-48-reel-reel-question-345962/ ), none of the various tape transport mechanisms are dirty or look worn out from lots of use. Compared to the other Revox machines in the shop, I think this particular Tascam has been doing nothing for a very long time.
OK, now for the problems...
So the rubbers on what I believe to be the pinch roller (sorry I'm pretty green here I know) has perished into a sticky black goo. The rubber around the other smaller tape guide next to it (sorry don't what that part is called) has similarly perished. How many bits of rubber and belts are inside this thing? I understand it has ceramic capstan drive but there are other belts in the unit too right? What other Tascam parts are compatible with the 48ob and what generally needs replacing internally to bring everything up to speed?
The other thing that is broken is the counter. It doesn't work at all. Any ideas on what would be involved in fixing this?
Another thing is that I have access to fresh RMGI sm900 which I was planning on using with the deck. I was planning on taking it to a repair shop as there are a few around here and have them service all the belts etc and calibrate the machine for this tape. I've read these units are pretty solid but how do you think it would fair as a portable recorder? I would be very gentle when transporting it. Would an Otari 8 track be better or worse for this? I would eventually like to learn how to maintain the deck myself but was hoping to get a pro to bring it up to speed in the beginning due to my lack of experience.
When I do go back to the shop to properly check it out, what should I be looking for on the inside? Is it even easy to get inside and check it out? They have the deck advertised as having a non-working counter but that's it, which seems strange as it's pretty obvious tape isn't going to pass nicely over that complete mess of a pinch roller.
Anyway, I sure there's something I've forgotten to ask but this is a good start I think. Cheers!
