E
ecc83
Hi Guys,
I just wanted to say thanks for all the help on this. -- Truly appreciated.
One last set of questions:
Is there a chain of command for powering up any of these? Meaning are there any considerations for making sure nothing goes on before something else? Or is that all kind of irrelevant?
Second, my phono preamp has a ground silverish-metal type thing sticking off the back... what needs to go on there? Some sort of cable?
Lastly.. I'm still a bit confused as to just exactly how the output from the computer gets to the speakers. USB--Interface--Speakers? --- All files heard from the interface are essentially funneled through the Audio Software? Isn't there an easier way to just connect something from the computer directly into the big knob and play everything from the computer through the monitors.. recorded tracks/ and everything else included?
No, there is no start up sequence, most of us just bang everything on at the start. Good idea to leave the BK volume pot at zero when you turn off so nothing blasts thru the monitors.
That is an earth/ground terminal on the pre amp. If your turntable has a separate earth wire, connect it there.
The BK is not a D to A converter (some controllers are) therefore it must be fed from the AI.
