E
Edge13
This is my first post here, so go easy on me.
Actually, I've been reading this forum for a little while and have seen some great advice. Thanks!
My problem right now (and for a while) is that I can't find a straight answer as to how to connect balanced equipment to unbalanced equipment. If I'm going from a balanced output to an unbalanced input, what do I use, TS or TRS? And do I need to do anything specific to that cable (ie. disconnect shield, etc.)? Is that the same if I go from an unbalanced output to a balanced input?
I've gained pretty much all of my knowledge from reading everything I can get my hands on. But I just can't find the answer to this one!
Thanks in advance.
BTW, what is the actual difference between -10 and +4? Is it that your signal to noise ratio is so low you can run hotter signals? I can't quite get that one.
Thanks in advance.
