A
ad0lescnts
I've seen this it's got cool stuff including a de-esser..anyone used them??
ad0lescnts said:I've seen this it's got cool stuff including a de-esser..anyone used them??
ad0lescnts said:you people make no sense!
ad0lescnts said:alright thanks man
Tyler
MISTERQCUE said:Wanna' buy an Alesis 3630!!?? Original carton,manual and warranty! Used only 7 times and makes a great effect box
for bass when gates are in use!
I disagree 100%......chalin27 said:I have a Nano compressor and it works fine on my stereo mixes. It's very clean and sounds spread out nicely with the right settings.
The settings are similar to some of the professional compressor's we use at my school. It's a good tool to use when trying to learn about compression.
chalin27 said:Lack of Experience with compressors???
Any one who has knowledge about mixing knows that the use of a dynamic effect has to do with a desired taste and creativity. Why would what I said earlier have anything to do with experience. I have used some outboard compressors and some from the console. It just depends on your taste. The guy was simply asking for an opinion. All you can give is that it is junk. As a professional or semi professional engineer if your going to offer advice give a little detail. If you have so much experience with this particular compressor why didn't you explain why you thought the compressor was junk. Simply saying the product is junk is not a good explanation to me. It also doesn't sound like an expierienced one either. I simply told him to give the product a try. It's a good learning tool. It's not the best compressor out but it's not a bad one either.
Bruce, make note of this, good pointer.chalin27 said:. You also have to realize if your music isn't clean before you compress it all kinds of noise will be brought to the front of your recording when you do. .
