frederic
I'm on Win2K with a firewire interface... I have 3 light
Hmmm, I have XP which supposively responds to firewire a little better then 2K. I used 2k before, and it was much worse. Maybe its the hardware... though I figured a P4 2Ghz would be good enough.
video editing packages I use... been a while since I used them though, so I'll have to look on the studio's comp to see the names.... as I recall, they all worked quite well and allowed me quite a few tools. I certainly didn't notice any dropped frames though.
If you get a chance, I'd appreciate it. No rush at all.
Before using the direct DV interface, I used a Hollywood A/V converter -- that unit dropped frames like you wouldn't believe when trying to work with DV -- so now I use it only if I need to transfer VHS to DV...
I did the same, except I used a USB/NTSC grabber. It was by far the pits. I could have used a USB webcam with better results!!!
Thanks for the reply, it was appreciated.
Frederic
