C
Chris Jahn
So, here is my mixing situation. I am in a smallish room, 8' ceilings, plaster walls (no treatment) the right side is open, so really its three walls. I have KRK Rockit 5's, they are head level, about 4.5' apart turned slightly in about 18"s from the wall behind them. The left monitor is (addmitadly and unfortunately) in a corner. I sit about 2-3' in front of them. Behind me the wall is about 6' away.
So, my problem? It's mostly the kick. Sometimes all lows, but 95% of the time it's the kick. I inevitably crank it, and it sounds just right. But then when I throw a mix in the car or an iPod for reference it's just slammed and clicky. One way I can gauge better is to listen against the back wall. If its "crazy" there it's usually crazy other places. If its just right there it's usually ok. When I do sit against the back wall everything gets really muddy, this aspect does not usually translate to my "true" mix. It's pretty much just the kick that I need to judge from back there.
Any suggestions based on what I described for getting a more realistic kick mix (and lows in general) without hsveing to sit 5' from my computer. And for the moment I can't change rooms, so I'm stuck with this. Thanks
