D
darnold
Well i guess i should have come here first to ask about the designs affectiveness, but basically what i realized is its either this or buying extremely expensive foam because ive looked everywhere for a vendor of rigid fiberglass around here, and even tried to get some special orders. First of all, no one around here even knows what im talking about, even if i call it all the other names it has.
So ive basically given up on that. So ive decided to use R19 batt insulation instead.
As i understand it, the absorbtion works a bit differently with this kind of stuff (similiar to foam) as compared to the 705 rigid fiberglass. Plus since its alot thicker its really narrowed my options on what i can build.
But when i bought the new studio i noticed the previous owner had similiar problems. But he had designed a bass trap in the Surround mixing room that i thought should be pretty effective.
Hopefully, because i pretty much copied the design even though i built mine alot smaller.
Basically it consists of a frame in the corner, much like Johns corner slot resonators, only its not an air tight box. It consists of 3 layers of fiberglass sheets. Two going adjacent to each other in the corner and one going across the corner. This makes a triangle with a bit of an airpocket in between.
They way i understand it, and i hope im correct, is this makes a very thick broadband absorber. Unlike a slot resonator or Ethan Winers bass traps that really on a resonating chamber that is tuned to certain frequencies. I just really hope that what i did created efficient bass trapping, maybe not as good as a resonating trap, but maybe still probably good? Id rather hear that i did overkill with it then not enough
Since i didnt want it to suck up all the highs so im going to put (havnt yet) put 1x2" furring strips down the front to reflect some of the highs back into the room. Im unsure exactly on how far i should space these however. Any suggestions? I could also alternate them like 1x2" and a 1x4" because i havnt cut the 1x4"s in half yet. So any suggestions would be great. So far they are looking really cool but i hope i just didnt waiste my time and precious money doing these if i could have done it a better way with what i have.
Guess i should have asked the pros here first what they thought. Also, its not too late to fix a few things or add a few things if it will make a big improvement so let me know.
Thanks a ton.
Danny
.Since i didnt want it to suck up all the highs so im going to put (havnt yet) put 1x2" furring strips down the front to reflect some of the highs back into the room. Im unsure exactly on how far i should space these however. Any suggestions? I could also alternate them like 1x2" and a 1x4" because i havnt cut the 1x4"s in half yet. So any suggestions would be great. So far they are looking really cool but i hope i just didnt waiste my time and precious money doing these if i could have done it a better way with what i have.
Thanks a ton.
Danny
Ha! Maybe 5 or 6 different size boxes. Hmmm, wonder where that comes from...eh?.
Wow. I would have thought the exact opposite. OK, thanks Steve. hmmm, damn, have to revise my drawings, AGAIN
