T
travelin travis
obi, after you get things running smooth, you might want to try tracking some things at different levels to see how it changes the sound. for example, record a vocal that peaks at -6 dbfs, do it again at -12dbfs, -18-dbfs-, -24dbfs. when you finish, adjust all the tracks to equal volume so that you can listen objectively without the volume of each track playing with your ears. normally, preamps are less noisy at lower gain settings.
the meters in your sound card control panel and cubase read dbfs.
