jpmorris
Tape Wolf
What you might want to do is generate a stereo sinewave on a PC, using audacity or something. If you feed in the left and right channels you should get the perfect diagonal line so you can check the scope is behaving correctly.
fgonza2,
Just to eliminate any confusion. You mention to disconnect the probe. By this do you mean the RCA cable's connecting the recorder to the scope CH 1&2? Put in in Channel 1 only mode in the Vertical section, or the trigger section? By "pos" knob do you mean position? And position 1 first then switch to Channel 2 and do the same?
b= set the volts/div knob to;100mV. Would that be .1 on the dial(s)?
By "now after that" do you mean set the sec/div knob to y/x?
What change are you referring to? the change as the test tape goes from the 1khz to the 10khz?
Lastly..what pictures don't load? Sorry to be so confused. I'm easily confused!![]()
the RMS meter needs to show -10 on the green scale. which is the -10dbV or 0.316 RMS. That will be the same level that you need to adjust the playback cards when running the calibration tape on both repro and sync mode.
How do you find the AQ-65 ? i am missing one for my MS16. Currently in the process of building an iPad remote control for these machines.
Yea, I have both connections at the same time. I have the generator, and meter connected to the inputs and the scope to the outs. But as you see... not viewing the ellipse. Must be a setting to change on the scope. ?
Wow..running the MS-16 @ 30 ips with no electrical changes required! That should be worth it's weight in Gold! Mine was factory set to 30. I inquired about setting it back to 15 and was told "it would be a lot to change".
