B
bdoughty2005
Those connectors are for the meter bridge. IMHO The meters can be installed in number of different places. I've got a set of them too. Lt lease that Is what it appears like to me.
Thanks! That solves one mystery.
Any chance that you have something prerecorded to listen to?
Unfortunately, no. But if I record myself talking or singing and play a good section back, it plays back perfectly everytime, leaving me to believe the problem is not with playback.
Noise from caps would be hearable regardless of input conditions if it is in the playback path (heads to line out). THis means that you would hear when listening to a tape without regards to what is recorded or not recorded on it.
Noise from caps on the record side would only be hearable for tracks that you laid down on a single or perhaps more than one channel but most likely not all channels. Again this would be without regard to the singal recorded or not recorded.
There is no noise at all when there is no signal. Apply just a slight signal, and the noise is at it's maximum.
OK, just listened to the noise. That "clicking" sounds like bad caps or noisy pots. Which is interesting as that it should be different per channel.
Is the DBX in or out?
Oh, On the clip you post I hear it from the start of the clip. Is this clip just the playback? I thought that youhoping that this is said that half of it was the input source. And that the input was clean.
I have disabled DBX for all tests. The recorded sample I last posted is all repro, not half input like the first sample I posted. The noise is only present if I montor a recorded signal on the repro head. It is not present if I monitor the input directly.
If I short the wires going to the record head directly to the playback head and monitor 'repro' there is also no noise. The noise seems to be occurring in the magnetic process of recording the signal onto the tape.
Cap/pot noise is random and unique per channel - it happens without regard to signal. Thus each channel may have noise but it will not happen at the same time (test - listen to 2 channels stereo and see if the noise unique per channel)
I tried the stereo test, and the noise is definitely different per channel. Also, the noise only happens when there is a signal present at the input.
If the noise is being generated in the record circuit then the pattern of noise should be the same on each playback of the tape and it should be unique per channel. (Test as above in stereo)
I have done this test. The noise is definitely the same on each subsequent playback of a previously recorded segment. It is unique per channel. Again, bypassing the actual heads in the signal chain (by shorting the record wires to the playback head) eliminates the noise, so it wouldn't seem that the problem is with the record amp circuitry, but possibly the bias circuitry.
Moving on to dropouts - looks like tape path issues - dirt, tension etc....
Just some thoughts off the top of my head.
Regards, Ethan
Thanks very much. It's all good stuff. The only thing you mention that I haven't been able to test is the tape tension because I don't have a tentelometer, but my instinct and experience with other tape machines tells me that the tension is within acceptable ranges.
