1
12milluz
I will be using a room to mix in and it has no treatment right now. Would hanging a few moving blankets across each corner help at all as temporary treatment?
I was given 5 of them for free and they are really thick and heavy. Thanks for the advice.
The arrows are in the direction of the sound from the monitors, correct?
...............No.
It will work on HF, though.
I'd bang that chick in the picture
Seriously though... What hasn't been explained is that rigidity (stiffness) and mass play a big role in how sound treatment is going to work. Generally Ownes corning 703/705 or similar is used in bass traps because of their ability to dampen low frequencies... These blankets you are using will dampen upper mids and the higher frequencies but this will give you a false representation of what you should be hearing because the lower bass frequencies will still be running rampant... Basically what will happen is the upper mids and higher frequencies will be dampened which is going to make it seem like your bass frequencies have been emphasized. Your mix won't have enough bass and too much mids and highs.
Room size, position of treatment, monitors, and even the shape of your room also play as factors in frequency response. If you can learn to compensate for the hills and valleys in the frequencies in your mixing room you can get by...
Best of luck bud!
and they work very well in a temporary setup or in a pinch.
If you put the blankets directly ON the walls then you are 100% right, but if you hang them atleast 6 inches away from the walls they dampen into the midbass region very well.
