T
TechNAB76
Hello everyone.
I'm kinda stuck in my studio with something technical. Over the years I've bought two set's of Monitors. One set is the Alesis M1 Active Monitors (The big ones) and the other set is the Alesis 520 M1 Active... the smaller ones.
For an audio interface I'm using the Edirol FA-101. Two computers, one selfbuild Quadcore PC with Windows XP and running Sonar Cakewalk 8.5 Producer and the other, an IMAC 20" inch with OSX 10.6 Snowleopard running Reason 4.1, are connected to the FA-101.
No matter what setting's I choose... I can only get sound out of one of the two studio monitors sets. I've double checked the wiring, the connectors even signal tested the monitors and cables and they all pass the test.
For example, within Reason parameter settings... I can check the boxes on the outputs that I want to use. 1/2, 3/4, 5/6, 7/8 & 9/10. The first two are the main monitor outputs. It doesn't matter on which output I connect the monitors to... it always comes out of one set.
Does anyone here have got that same problem?
Thank you very much in advance for your advise.
