Monkey Allen
Fork and spoon operator
If my cable ends in a 1/8" mono jack and I connect a stereo adapter jack onto it, will my signal be converted to stereo?
Monkey Allen said:Is it common to record in stereo? What are the advantages? Does it mean the quality will be better?
Monkey Allen said:Does this mean that the 1/4" output is the Left and the XLR is the Right? and I can use a Y splitter in order to send a stereo signal to my 1/8" soundcard line in?
That sounds kind of weird to me. It doesn't sound right.
I have heard that it is wrong to send a mono cable into my 1/8" stereo soundcard line in input.
So if my preamp device is mono, how would I get the signal into my soundcard properly?
Monkey Allen said:Ok cool. From your point of view, could I use a Y splitter anywhere in the chain to get a stereo result? I have been getting advice elsewhere and I am being encouraged to use a Y splitter. But I don't see how I can use one on my set up. I doesn't make sense to me.
So it's not "quality suicide" to plug a mono 1/8" into my stereo line in? Like you say, it will just record to the left channel, and as long as I configure my software to receive Left/Mono, I will be ok?
scrubs said:Since your mic is mono and your preamp is mono, you CANNOT record in stereo. Period. Using a splitter makes no sense. There is nothing to split. It is a mono source and should be recorded as such. There should not be a problem with plugging the mono cable into a stereo jack. Just, as you said, configure everything to record from the left channel. Good luck.
Yes.Monkey Allen said:So from my 1/8" stereo line in from my sound card, I would have a Y splitter that ends with a L and R....and then I would use, say, the L from that Y splitter to plug my preamp output into?
Is that correct?
As I said in one of my earlier responses, using a mono plug into a stereo jack will cause the "hot" side of one of the stereo connectors to contact with the sleeve part of the mono plug, this will ground it first to it's own ground, right inside the stereo jack, and will also connect it to the ground on the preamp (or whatever) that's plugged into it, this can cause humming, hissing, crackling, noise to get into the audio signal that you're trying to record, it's certainly not a good way to hook up things for recording.Monkey Allen said:You disagree with scrubs when he says there is really no problem with plugging a mono cable into a stereo jack?
Monkey Allen said:If the first thing I said in this post is correct, then I understand now...finally.
I think you should shy away from Creative soundcards for recording pretty much and try looking at a Delta 1010 or other M-audio soundcards.Monkey Allen said:Do you guys rate those "live drive" soundcards where you can plug into a front panel that is wired to the soundcard in the pci slot?
Are they good for music recording if they have a 1'4" jack?
What soundcards should I be looking into for music recording?
Which is better - internal or external soundcards?
