RideTheCrash
Member
3 years ago I posted a similiar problem and I fixed it by removing a cable from my crappy, crazy setup.
I just started recording some tunes recently and I have an electrical buzz present. I unplugged everything from the mixer and plugged in some headphones and I still get buzz, so I've ruled out my signal chain to the computer at the moment. I did some recording back in the summer and I didn't have this problem. I have re-routed some cabling and stuff for power, but I try to keep my power and audio cables away from each other as much as possible. I've tried a wall plug and a power strip on a different plug in the room and I still get this nasty buzz. I've unplugged and turned off lights and other things in the room which no change whatsoever.
I use my board to tap off the preamps and use the inserts to go to my soundcard. If I turn up master faders the buzz changes and disappears and comes back. The pots are fine, I put in new ones about 2 years ago. Either way, it doesn't alter the signal to my card, which is only controlled by the gain pot. I have no idea what is on what breaker in this house, but do you guys have any suggestions?
