Mix this acoustic track
  • Thread starter Thread starter MusicKid94
You are talking about "mastering" , mixing would be balancing the inside track, mastering would be improving the final result
You'd might want to make the guitar a bit louder btw...
yep it's mastering, I hope he realises the difference
The guitar is mixed very low, and as a result there's a lot of background noise that even decent noise reduction tools can't resolve without causing a high loss of fidelity. As soon as I tried to bring the mix level's up, the background noise/hiss was just unacceptable.
yes ideally it needs recording with the mic in a better position where the vocal/guitar balance is far better in omni if possible or 2 fig 8 mics.
I also felt the guitar sounded muddy no matter how hard I tried to remove it, when you try and remove it you sacrifice the warmth of the vocal and it's too much of a compromise.
I think this was recorded with a phone, because there's a dramatic cutoff to the higher frequencies and the background noise is common to those cheap mics in phones.
