MrBoogie
Member
I recently scaled down from a half stack to a small 1x12 combo (Mesa F30). Today was my first attempt at recording it. Strange thing is, with the amp on STANDBY, as I move my sm57 closer to the speaker it starts to pick up a hum (sounds like 60hz hum I believe) at about 6 inches or so.
Things I tried to fix it:
1) tried a better mike cable, actually tried 3 different ones just in case
2) plugged into a different outlet / move the amp to different locations
3) (well, I don't have another dynamic mike to try)
4) plug an extension cab into the amp and miked that instead.
#4 is the one that worked for me. This leads me to believe that with such a small combo, when putting the mike up against the speaker cloth, it is close enough to the power supply to be affected by the transformer. Is this correct? If so, I guess this is my only choice for miking this wonderful sounding little amp. So much for scaling down
Is this a common problem with really small tube combos? I never had this issue with any ss combos I had in the past.... of course those didn't need the sizeable power section that this little beast has.
MrBoogie
MrBoogie
