Milnoque
Resident Curmudgeon
A couple of Recomendations:
This guitar may mave been subjected to high temperature and humidity. There is a chance the wood contains more moisture than is ideal. It is a good idea to keep it from drying out too quickly. Use an appropriate humidifier and keep it in it's case when not being used. Play it frequently. This is assuming there is no visible moisture damage present.
Get a good quality guitar polish and clean the guitar thoroughly. There may be residue from the smoke that could harm the finish over time. Be very anal about this.
Gently tap all over the body and listen for rattles or unusual sounds. Reach inside the body and feel for anything loose. If the guitar got warm enough, some glue joints could be compromised. A once-over by a qualified luthier would be a good idea. Pay close and frequent attention as this guitar acclimates to your environment. If an issue arrises, it helps to catch it early and address it pronto.
None of this is meant to scare you. If you don't smell a strong smoke smell or see any damage there is probably nothing wrong with it.
Good luck and great tunes.
