mshilarious
Banned
DOS talk makes my chick hot!
Mmmmm . . . autoexec.bat . . .
Don't blame the language.i'm not going to tell you how to destroy your recordings with midi.
i'm speaking of recording midi performances. note timing and velocity come out slaughtered.
Also, it uses MIDI channel 1 by default
I don't understand the channel thing.
Whoa man. I thought I was bad!
OK, MIDI primer for Midiots like me and you. People that actually understand this, please correct me. But I can explain it in analog-man's terms
OK, a MIDI channel is just like a TV channel, except there are only 16 of them. Pretend like it's old-time broadcast VHF TV. Let's say 700 Club is on channel 13. You don't want to watch it? Turn the channel!
MIDI data can be broadcast on any or all channels. Most controllers will
default to channel 1. What is MIDI data? Let's keep it simple and just talk about a few: note data, program change (switching between patches), bank change (switching between banks of 128 patches). That is probably most of you want to do.
Now, you have a hardware synth, it has some cool sounds, you want to record them. Why should you use MIDI? Well, if you want to sequence inside your computer, it needs the MIDI data. So you plug in your synth and play away. Your synth is sending all kinds of note on (press a key) and note off (let go) info to your PC. That data also includes velocity info, expression, pitch bend, anything you are doing to that keyboard and its pedal, wheel, stick, what have you, it's going to the PC.
On Channel 1. But let's say for some odd reason your software is watching Pat Robertson on channel 13. It doesn't care what's on channel 1.
Now, the software CAN record all 16 channels at once. It's like TiVo or something. But if nobody tells it to listen in on Channel 1, it doesn't record your performance.
So why would you want more than one channel? Well, if you playback your whole track with lots of recorded MIDI data, and you have a lot of different parts, the softsynths and/or hardware synths gotta know what part they should play. Otherwise all of them would play all the parts! So each part gets its own channel.
On the input side, you could be jamming away on two different controllers, and capturing their MIDI data separately by setting them to different channels and have your PC record both channels.
More here:
http://www.borg.com/~jglatt/tutr/whatmidi.htm
lol
config.sys......ooh la la
Yeah, why should I use midi? If the hardware synth had some cool sounds that I wanted to record, couldn't I just plug a 1/4" cable into my mixer and record it as an audio file?Now, you have a hardware synth, it has some cool sounds, you want to record them. Why should you use MIDI?
Define Sequence.Well, if you want to sequence inside your computer, it needs the MIDI data.
Define Sequence.
Sorry.I'm not trying to waste your time, I'm trying to understand this red-headed stepchild of my hobby, and it's like high school algebra, if you miss one thing you're fucked for the rest of the year.
you dont have to use midi especially if u are only using one keyboard but its useful especially if you are using more than one. The best thing you could probabaly do is just dive in head first to really get a good understanding of what midi does its a really great tool. Its a lot more than time correction. Sequencing is just another way of saying arrange. a time sequence in otherwords.Yeah, why should I use midi? If the hardware synth had some cool sounds that I wanted to record, couldn't I just plug a 1/4" cable into my mixer and record it as an audio file?
Define Sequence.
Midi is just like DOS willis...you DO know all about DOS don't you?
midi is nothing more than communication of devices lol. it has nothing to do with if u can play or not. midi controllers that control soft synths are controled via midi. u dont have to quantize and it doesnt have to fake it for u lol. a motif is a midi device because u can sync it with any other midi device u want to. it has nothing to do with actual playing skills your ignorance is laughable.
If sticking a carrot up my ass while mixing my drum tracks would make the end result better, I'd do it.
The end result for the bunny rabbit not looking so good at this juncture.
“Hey! Where you goin’ wit my f**kin’ carrot, my man?”
