M
MoonManiversity
When I have started my CPU and have all my sound muted , not a single program open....
I can still hear the microphone as though I had a track enabled and was intentionally recording.
The reason this is a problem is that when I do enable a track that my mic is set up with there is immediate latency/unwanted echo
The now enabled audio track records both me initially singing into the mic, and the playback I was hearing from start up. I've seen tracks offset for a "fatter" sound, but this is just not that effect.
So far I believe this to be a windows settings issue due to my opening statement.
Here is a list of my hardware, followed by software settings.
Presonus AudioBox usb interface 2x2
Studio one 2 artist with some additional content
Acoustic Guitar (Austin brand)
Shure Prologue Microphone (Poor exterior, but I have heard this mic produce perfect sound using my current setup, with the one change more than likely being the variable setting being my problem.)
I have checked cords on the acoustic as I have multiples, I notice it picks up static and the bar to the right og the track that shows the levels of pitch (I think my jargon is right?) is constantly at about 10% (There is occasional popping as well, which is new, but that is optional answering.)
In the sounds area of the control panel I have:
Playback: HDMI High Def Audio Speakers NOT PLUGGED IN.
Speakers AudioBox USB. ENABLED
Speakers High Def Audio device DISABLED.
PNP Sound Device DISABLED (This is a USB Mic that I use for Dragon Naturally speaking.)
Recording: Line Audiobox USB ENABLED
Microphone High Def Audio Device Unplugged DISABLED
Microphone High Def Audio Device DISABLED
Thank you for your time I read good reviews about where to post this and they sent me to you gentlemen and exceptions.
-Andrew
-Andrew
