Increased Lyric Intelligibility?
Yes, Sufjan Stevens actually mentions seven swans in the song, “Seven Swans”.
* An easily discerned benefit by even non-audiophile ears, and an undervalued indicator of noise removal.
Musical, Well-Defined Bass?
Believe it or not, there is a musical note behind that rumbling.
* Wall-shaking bass misses the point if it disguises the music. Every acoustic bass instrument has its own character and tone; you'll know you're on the right track when you begin to hear these signatures through your stereo.
Larger Sound Stage?
“I can’t believe that’s only two-channel! There’s surround-sound speakers hidden in the walls
right?”
* Welcome to two-channel done right. Your speakers disappear and musical images shoot at you from all directions, sometimes scarily so! Higher, wider, deeper . . . you name it. The sound stage grows as more signal is permitted to flow through these large gauge conductors.
Less Listener Fatigue?
No, we can’t cure a hangover, but you can say good-bye to that pressure in your ears after a
listening session.
* Not sure where that headache came from? Fatigue occurs quickly when listening to poor sound. It's your body's way of telling you that something isn't right - you'd be wise to heed its advice.
Lower Noise Floor?
Where’d the hum go?
* Cables function as antennas that pick up energies which become amplified through your speakers. Our True Float Ground technology shields so well you can even criss-cross your cables without adverse effect.
