R
robin watson
In an attempt to get some consistency in meter level indication between my HD24 and Soundcraft 6000, I performed the following using the built-in 700 Hz test tone on the Soundcraft:
Sent the test tone to all channels on the HD24 and set record levels to 0db, or just below onset of clipping. The Soundcraft meters were showing +6dB or so - well into the red. I then calibrated each meter to indicate the same (0db) levels as the HD24. I also changed the meter reading over to VU (instead of peak reading).
I hope I did the right thing here. The meters are no longer slamming into the red, although the overall modulation now does seem a tad on the low side, but better than before.
If anyone thinks there is a better (or actually correct) method of calibrating, please let me know....
Cheers.
Cheers.
