R
		Reds Garage
This is my first post, about work on my first album. I recorded my band off the floor, and overdubbed vox and lead guits. I had a few phase issues which I tried to deal with using eq and panning, but I have left some of it as I was trying to capture a live feel anyways. Everyone seems happy with the mix, as am I. My problem is with the 'mastering'. I've bounced the songs down to split mono, and am now trying to bring up the volume and capture the peaks with compression on each of the individual channels, and a comp on the master out. I noticed in a playing back an older mix that it seemed more open, and the most recent one in which I used more compression is squashed beyond use. I couldn't even listen to it. (don't know what was going on, maybe too much beer?  ) So, a bunch of questions: do I eq the L and R individually before each channels compressor, or should I try it after? Should I be eqing the master out instead? Will reverb help with the high end loss that seems to be happening with compression? Does adjusting the release time of the limiter/compressor to fit the tempo help at all with the sound? I am actually not too concerned with making this sound "radio friendly", just the concern of the volume level not matching that of other CDs when played on home stereos. Any suggestions are appreciated. Thanks guys!
edit: the style of music is rock/punk with an old school country twang
 ) So, a bunch of questions: do I eq the L and R individually before each channels compressor, or should I try it after? Should I be eqing the master out instead? Will reverb help with the high end loss that seems to be happening with compression? Does adjusting the release time of the limiter/compressor to fit the tempo help at all with the sound? I am actually not too concerned with making this sound "radio friendly", just the concern of the volume level not matching that of other CDs when played on home stereos. Any suggestions are appreciated. Thanks guys!edit: the style of music is rock/punk with an old school country twang
		 ) I couldn't care less if it's loud or not within reason. I mean, you don't want something so quiet you lose resolution or the playback system can't get it up loud enough .... but other than that, I just turn up the volume and I suspect most listeners do that also. I do see people listen to stuff and turn it up if it's not loud enough so I'm sure that most stereos still come with volume controls.
 ) I couldn't care less if it's loud or not within reason. I mean, you don't want something so quiet you lose resolution or the playback system can't get it up loud enough .... but other than that, I just turn up the volume and I suspect most listeners do that also. I do see people listen to stuff and turn it up if it's not loud enough so I'm sure that most stereos still come with volume controls. Maybe this is part of the problem?
		 (my band by the way is made up of musicians who do NOT listen to radio crap, and have no desire to have that BIG sound, in fact believing 'that sound' to be quite sterile and lifeless, as do I) So here I am now trying to figure it out. Thanks for the feedback guys, off to the studio now to see what I can do.
		 )? Or am I just reading you too literally?
