JCH
El Nacho
I think it's a good idea to have a speaker connected when you're on standby. The center tap of the output transformer is still seeing high voltage.
look i've worked on more marshalls than you'll ever own... that said have i worked on every variety??? no... however i have never seen any amp where the B+ voltage was at the output tranny but not the tubes... i have never seen an amp where the voltage to the output tubes was lifted but the preamp tubes were not... in fact if ya look at scehmos of most (all)amps the power tubes are the first ones to get the supply... then each subsequent stage gets slightly less voltage by virtue of a resistor and secondary supply filter so as to minimize cross talk like artfacts... if you can provide a schem of this amp i would be glad to look it over for you... and yes i do know something about it... i've been factory certified by marshall fender boogie crate ampeg and others...
Does the Marshall in question maybe have a SS preamp section?
No. It has clipping diodes, but a JCM900 has tubes for the pre.
