O
ofajen
Daddy-O Daddy-O Baby
BigRay said:well, multipattern mics arent ideal either(in purist terms, I am no purist, just stating the info for whoever wants to hear)..only single pattern figure 8s are ideal. Same with Jecklin Disc..the original german white paper stated that only pure omnis(ie not switchable pattern) should be used for "exact" results.
Agreed. I was just offering some options to try that might actually work well enough for the intended purpose and save some money. We had a discussion about the differences between pure omni mikes and the omni position of multi-pattern mikes recently. The Jecklin disc requires an obstruction (the disc) close to the mikes. Multi-pattern mikes in omni mode won't produce the intended result with an object so close to the capsules. As you say, only true omnis can produce the sound of an actual Jecklin disc.
By the way, BigRay, you seem to like the AT 4050. It's the only multi-pattern mike I have, and I like it too. Probably because, for being a multi-pattern condenser, it seems to be one of the more accurate ones. I seem to recall David Josephson recommending it to me for that reason over some of the other multi-pattern mikes in that price range (under $1000). I used to have two and I sometimes wish I still had them both.
Otto
