N
nononsense!
Sure. To say that the answer to 2+2 is 4 is an easy answer and it is 100% accurate.
But just because easy answers *can* sometimes be accurate doesn't mean they always *are* accurate. Your point about +4dBU is inaccurate when it comes to computer sound cards, when it comes to signals with extremely high crest factors, whether your're talking about average levels or peak levels, when it comes to consumer audio gear, in situations where you want to take advantage of circuit saturation, etc, and many more examples. I'm not being difficult or overly hard; I'm stating the truth of the real world.
Tell me, what is the best color? What is the temperature of the planet Earth? What is the best signal level? Should I run into that burning building to try and save that person? What do you mean by "best"? Why do I love that girl? What does average mean? Should I believe you? Which hobby is best for me? Give me an easy and accurate answer to any of those questions.
G.
The color that gives the most fun in the given situation.
The temperature varies, look at this map for the various temperatures. The temperatures also vary in time, they cannot be predicted with 100% accuracy yet.
A factory should know that by doing their arithmetic, not the customer.
You should if you wouldn't die yourself.
The thing that is better than all other possibilities in that particular situation.
There could be various elements that could explain that, the elements are: (on the left you see the element on the right the weight factor that explains how important that element is)
The middle of 2 numbers, for example 2 and 6, the middle is 4.
If it is probably so that I am right then you should believe me.
The hobby that gives you the most pleasure.
