cincy_kid
Active member
So, I ended up buying the Behringer UB 802 for my first mixer and got a Shure SM57 as well. My next purchase will be a new sound card but for now I am stuck using the Creative SBLive sound card with the 1/8" inputs.
Anyways, the first problem is that its hard for me to tell which input is the LINE IN. They are only labeled with symbols and few letters. They go something like this:
1. serial port
2. ((|))-2 (i am guessing its the 2nd line out)
3. ((|))-1 (i am guessing its the 1st line out-this is where I plug my speakers into normally)
4. 0==-- (its drawing of microphone so we know this is mic input that you are not suppose to use)
5. ((|)) (this one has arrow pointing into it where the 2 above have the arrow pointing out, so I am guessing this is the LINE IN?!?)
6. DIGITAL OUT
If that is true and #5 above is the LINE IN, then I am having another problem.
- I have the shure SM57 going into the XLR in channel 1
- I have a 1/4" going from the mixers "FX SEND" into the LINE IN in my soundcard with a jack that changes it frokm 1/4" to 1/8"
- I have my headphones plugged into the PHONES jack in the mixer.
When I sing into the mic, the green signal lights go just fine and I can hear myself perfectly in the headphones (although only in one ear..is there anyway to get into both ears?). But the problem is I am not getting a signal in ACID 4. The green lights wont move at all in ACID, and when I record it anyway I get nothing on playback.
I have tried plugging into every input in my sound card now and got the same result except for when I plug into the dreaded MIC input. Then the lights go crazy in ACID (i am guessing since its a very high or strong signal). And when I record that way it records except its all crackly and very distorted and staticy.
Any advice on what the heck I am doing wrong or can fix this? I realize that when I get a better card it will help dramatically, but isnt there a way to get thru my cards LINE IN now and get sound that dont crackle?
Thanks again for all your help
1. serial port
6. DIGITAL OUT
