To do the update, read the readme file...
Updating the JV-1010 Operating System from Standard MIDI Files
Use the following procedure to update the JV-1010 to the
latest system version. The updated software is provided as
15 Standard MIDI Files, on a DOS or Macintosh formatted disk.
The tools required are:
* MIDI sequencer (software or hardware) that can load DOS or
Macintosh Standard MIDI Files
* MIDI cable
* JV-1010
* JV-1010 System Software update disk
Update Procedure
1) Power off the JV-1010 and connect the MIDI OUT port of the
sequencer to the MIDI IN port of the JV-1010.
2) Rotate the PART dial to select 14, then rotate the
CATEGORY dial to select Guitar/Bass.
3) Power on the JV-1010 while holding down VOLUME and VALUE.
4) After 3 seconds, release the dials and then press VOLUME
again. The display should read "nid."
5) Play all Standard MIDI Files from the MIDI sequencer in
sequential order.
6) After all SMF's have been played, power off. The system
software of the JV-1010 has now been updated.
You should reset the JV-1010 after it is updated:
**Warning: When you reset the JV-1010, all user parameters
will be erased and set to the factory settings.**
1) Power on the JV-1010
2) Press the VALUE dial to select any mode except PATCH mode.
3) While holding VOLUME, press VALUE.
4) Rotate the CATEGORY dial to select Piano. The screen will
display "Fct."
5) Press VALUE, the screen will display "Sur."
6) Press VALUE again to perform the factory reset.
(c)2000 Roland Corporation U.S.
