B
Beck
Guest
regebro said:Well, compared to you he is of course the perfect display of humility. But then, so are most people.![]()
Yeah, I quess that's nearly everyone but you.
Ropa inte hej förräns du är över bäcken!
regebro said:Well, that's how dr ZEE, Beck, acorec, DamnYankee and you come off to, so there ya go.
And all i'm doing is that I refuse to say that I don't know what i'm talking about. Is that arrogance? Possibly.
cjacek said:Ahh, the layers of "regebro" are peeling off .... finally ....![]()
snow lizard said:The mention of vinyl is kind of interesting here. (Sorry if this is off topic...)
This reminds me of an EP (12" 45rpm) that my brother bought 20 or so years ago. He was very much into Kiwi music (has a number of the original pressings of various Flying Nun albums including ones by Toy Love, The Clean, Bailterspace (sp?) and early Headless Chickens).snow lizard said:Now for audiophile concerns, there are ways around this to an extent. You can increase the pitch (pitch in this case is the distance between the actual grooves, similar to a screw thread or airplane propeller) which actually makes the groove wider and deeper. It also reduces playing time. Imagine less than 15 minutes playing time per side on a very flat, concentric, heavy piece of vinyl. This is good.
cjacek said:Btw, what's the status on records now ? Are vinyls still made and has the supply increased to fill the new demand ? What about reissues ?
Back in the old days, you could go into any Radio Shack and find a selection of no less than 6,000 different types of stylus to play your records on. Some were cheap. Some were exhorbitent. 5,982 of these models are now extinct. This was all part of the quest for better audio, or else something you could afford, which people have largely given up on be it analog or otherwise. There were also A LOT of very good bands signed to the major labels, and there were even more labels. The infection and subsequent plague which came to haunt the music industry is beyond the scope of this punked up rant, but many aspects have little to do with digital, analog, vinyl, or even George Clinton. Could he even imagine the shadow of The Village People on the horizon? I honestly don't know. I won't even mention MTV.
Vinyl had its own set of problems, similar to digital. Once people started figuring out how to make really good vinyl, the record companies decided to cheap out and not make the records so thick. This made for records that had poor bass response and generally lower sound quality. Also, the actual master plates that are used to stamp the records wear out during normal use, so the initial 10% pressed were the highest quality ones, while the subsequent 60% or so had less robust quality, but things held together fairly consistantly anyway. The tail ends of the runs to press this stuff were low quality, but there was still that long shelf in the middle where things were "ok" and fairly consistant, after a drop in quality from the first couple of hundred pressings. Sometimes the center hole for the turntable spindle ended up off center to the grooves for some absurd reason, resulting in pronounced pitch modulation effects. Very annoying.
The mastering process for vinyl production is unique unto itself, and highly specialized. You basically cut a spiral groove on a circular flat plane surface using a record lathe. Want the bass to pump harder? It'd cause the needle to warble too much, or in an extreme case actually kick it out of the groove.
Somewhere along the line, some very nice record company person came up with the idea of making the total playing time on a single piece of very thin (and usually always warped) vinyl equal to around 60 minutes. The result was fragile media, shallow, fine pitched grooves and much lower fidelity, thereby increasing the value to the consumer because the record company didn't bother with the expense of doing it right.
Surface speed also becomes a concern. When you drop the needle at the beginning of a vinyl platter, you're at the outside diameter. The RPM of the turntable is fixed at (let's say) 33 1/3. Surface speed is what you get when you use inches per minute instead of revolutions per minute. The fidelity of vinyl is much better at greater diameters, because there's more inches per minute. Think of it as a radial variation in sample rate. You record a song on a tape deck that's constantly slowing down - you start at 30 IPS and by the end of the song you're at 8.3 IPS. This is not how tape works, but it's exactly what vinyl does.
These days, truly audiophile vinyl is a niche market. Truly audiophile vinyl always has been a niche market throughout the entire existance of vinyl, by the very nature of the real life obstacles of how it's manufactured.
The 2 basic types of turntables are belt drievn, or gear driven (usually called direct drive). Belt drive turntables will create a static charge that the vinyl will pick up and retain, while direct drive turntables won't. Despite maintenance issues from replacing belts and discharging your vinyl before playing it, belt drive turntables run much more quietly, enabling more dynamic range, and therefore a more robust listening experience. Other things to look at on a turntable are the needle weight balance controls and anti-skate adjustments. Very essential if someone wants to take it to the next level and optimize the cartridge and stylus for best results. The cheap plastic turntables with no adjustments never sounded very good.
Much more important than the numerous obvious flaws with the technology were the engineers that made it work regardless of the obstacles, and without blaming it on analog. The results were sweet and people listened.
sl
Except for the most popular turntable of them all of course:DamnYankee said:3. Direct drive turntables SUCK - period. That's why they're no longer made.
regebro said:Except for the most popular turntable of them all of course:
http://www.panasonic-europe.com/tec..._detail.asp?range=turntable&prodid=SL-1200MK5
But, ok, that's not an audiophile product, so that was unfair.![]()
Dr ZEE said:For what?
For an "enlightening revelation" about what he thinks about cheap gear. The point is: "If you do not have anything positive and usefull to contribute for a home recordist, but all you can do is to keep pointing out that all the problems are in the very fact of being a home recordist and using home recordist's gear, then just DON'T.
No, not for those reasons. I think he has a respectably detailed and intricate tracking process, and the overall mix to my ears sounds superb, that's why I personally have respect for what I've heard. But the end sound of his rock clips just don't do it for me, and that's subjective. And you're right, he can be a bit of a recording elitist, and that's annoying.
...then, it ain't gonna be 'home recording', man
If I had money and time, I would love to record at a large studio. Don't know that I would record at Blue Bear because pretty much all I do is rock-n-roll, the particular style that I found least attractive of his clips. If you've heard them, though, you have to admit the piano sound he got is sweet. Anyway, I would record somewhere where a person much more knowledgeable than me was at the controls and with a setup that included a treated room and decent gear, and a big 'ole fat 2" 24 track machine to track to...you know, a studio. Biggest studio I've recorded at about 15 years ago I believe was 24 track. Very nice studio, equipment, atmosphere. Guy at the controls liked processing, though, and it tainted the final product. I remember this little 8 track place that was pretty decent too. Anyway, not that I don't like my setup or my abilities, but they are not where I want them to be, though in time they will be. Setup is fine for me, just the abilities I need to improve on. So given the time and money at this point in my life, I would love to track in a top-notch studio under an experienced engineer. No, it wouldn't be home recording then, but I'm not married to home recording, it is just what I do and can afford right now.
You've got me thinking about Blue Bear ripping on cheap gear now. He is pretty elitist, isn't he? A hypothetical situation with me and Blue Bear...me: "Hey I just got a MSR-16, my first reel to reel!" a typical Blue Bear response: "too bad it's going to sound like shit because it isn't a Studer or a $5000 hard disk recorder."
Yeah that can be annoying Zee, I do not disagree with you for a second!![]()
Seeker of Rock said:The worst part of it, that there is a very good chance, that (hypothetically speaking!Dr ZEE said:A hypothetical situation with me and Blue Bear...me: "Hey I just got a MSR-16, my first reel to reel!" a typical Blue Bear response: "too bad it's going to sound like shit because it isn't a Studer or a $5000 hard disk recorder."
) he never had nor worked with MSR-16.... but it does not matter for him ...., 'cos he knows, that cheap stuff sucks. See?
(And of course, naturally, anything below the dead tree branch, upon which The Crow seats, can be and unavoidably will be shat over. Anything below - is cheap. Naturally.)![]()
weather you married to home recording or is it just a secret affair, but home recording issues are the reason why your are blah-blahing here. We do talk about "sh*tty gear" here and do discuss "sh*t" , surrounding "sh*tty gear". It just does not get any sh*ttier than that. heh heh. I hope I have not over-used the mighty word yet ...or have I?
Hey, man, When your 'dreams come true'..heh heh, and you go and record your platinum record at some Fat Grizzly House Records Studios © in LA, NY or London or what have 'Ya
.... are you going to come back to this board to "discuss" your experiences? Well, it is possible, which is fine.... it will be 'off topic' thou .... actually 'off any topic' . However, it will not be fine, if you start fireing right and left like a mad dragon stuff like: "Hey dudes.... quit this shit. If you want to record something for REAL - do what I did. Go to Grizzly House NOW!" LOL
/respects
FALKEN said:damn you're a piece of shit. it is you that "degrades every thread you post in". who cares if people are not backing up their opinion with fact?? this thread started out asking for opinions. fucker.
Dr ZEE said:The worst part of it, that there is a very good chance, that (hypothetically speaking!) he never had nor worked with MSR-16.... but it does not matter for him ...., 'cos he knows, that cheap stuff sucks. See?
weather you married to home recording or is it just a secret affair[/i], but home recording issues are the reason why your are blah-blahing here. We do talk about "sh*tty gear" here and do discuss "sh*t" , surrounding "sh*tty gear". It just does not get any sh*ttier than that. heh heh. I hope I have not over-used the mighty word yet ...or have I?
/respects
I'm not sure if staying on the original topic is still relevant at this point but I'll give it a shot.Tim Walker said:Is it a price issue, or nostalgia, or just because you have been recording and mixing that way for ever and reluctant to change?
Do you see yourself going all digital in the future?
I'm just curious at to the mindset of an analog fan.
thanks
tim
