just a quick yes or no on PAs
  • Thread starter Thread starter Afrosnatcher
A
Afrosnatcher
Hi. i know this will sound retarded but i just wanna check this before i work out how much i need to spend.
in a DECENT PA does the chain generally go
Mic -> Mixer -> power amp -> speakers?
cheers :D
Yes, although in a small PA the mixer and power amp are often built into the same unit.
Pretty much, but usually (in a "decent" system) you got:
Mic -> Snake/stagebox -> Mixer -> Crossover -> power amp -> mains
Mic -> Snake/stagebox -> Mixer -> EQ -> Crossover -> power amp -> mains
You forgot the EQ
You forgot the EQ
Mic -> Snake/stagebox -> Mixer -> EQ -> Limiter -> Crossover -> power amps -> mains
You forgot the Limiter.
Don't want to blow those mains, man!
And you usually have a plurality of power amps.
Light
"Cowards can never be moral."
M.K. Gandhi
You forgot the EQ
Light
M.K. Gandhi
And of course, if you REALLY want to do it right, you have
Mic -> Stage Box -> Split Snake-> Signal A from the split goes to the monitor mixer, which has -> insert EQ's on all monitor busses -> monitor limiters -> monitor power amps -> monitors
and Signal B from the split goes to ->FOH mixer -> FOH inserts (usually compression or gates) -> back to the FOH mixer-> FOH effects -> FOH mixer returns -> output from the FOH mixer through the Matrix outputs to -> FOH Limiters -> FOH EQ's -> FOH delays -> various speakers, including mains, delays, front fills, and subs
If you want to be really picky about a really decent PA.
But if anybody wanted to answer the question, yes, you can go Mic -> mixer -> power amp -> speakers. It is common to have the power amps as a part of either the mixer or (even better) the speakers. Active speakers have all sorts of advantages, particularly in a low cost system, but they are also considerably more expensive. It is also common to have either inserts (typically dynamics such as compression or Gates) and/or effects (typically reverb or delays, though there are other possibilities).
So what you discribe is a minimum, if you are using it for a small crowd. The larger the audience, the more you might want to think about hireing a competent sound guy who can not only do the mix for you, but also design a system which will sound good.
You know, I really can be snarky sometimes.
Light
M.K. Gandhi
cheers :D
Yes.
:cool: :cool:
:D​
Yup, that works much better than shouting into the speakers and having it come out the mics. Much louder, too.
ok. cheers guys. i have the mixer so all i need now is power and speakers! im tinking of making my speakers with maplin speakers so the power amp would have to be bought!
