Junk Telecaster
  • Thread starter Thread starter crazydoc
On to the bridge. I hacked an appropriate piece out of a steel plate from the copier.
Shaped and sanded (yes, that belt sander was a lifesaver for this project. :))
I downloaded a pic from the Stewmac site (along with dimensions) and made a template. I'd cut the bridge too long, so I shortened it.
I used a Dremel tool to smooth the inside of the pickup cutout. It jumped out and scored the surface several times. I was too lazy to get all the scratches out. C'est la vie.
Saddles were cut from more copier shaft. Drilling and tapping the holes for the height adjusting screws was the most tedious part of this whole project. Six 4-40's. And I was thrilled I didn't break the tap! But I did break about 5 bits.
These are the springs. Ball point pen springs were not stiff enough, so I used clothes pins.
The finished bridge.
Good God, man, such detail to doing it ALL from scratch. Do you grow you own freakin' TREES, too?
i'm dying to see what you come up with for the strings. hubcaps maybe? silverware? no idea, but i know it'll kick ass! :D
looking good, dude. totly jealous. i'd still be working on getting a splinter out of my finger from day one.
Sorry to disappoint, but I used a set of real strings I had around. In Africa, I've seen some musicians use unbraided bicycle brake cables
on their tin can guitars.
The neck plate is from the same steel as the bridge.
Screws are from 3" coated deck screws - cut to appropriate length and heads rounded.
Trial neck fitting.
On to the pickups. Forms were made from PC board in the copier. I picked the one with the fewest components, desoldered them and ground off the copper pads (belt sander, of course.)
Drawn, cut, and drilled. The bridge pu pole pieces are more copier shaft.
Glued. The neck pu uses magnets from the door latches of the copier.
I used hard drive magnets for the bridge pu. (This pic after it was wound.)
On the pickup. Worked fine after that.
