NL5
Unpossible!
Is there a tube pre (real tube - not toob, or tewb) that has both input and output gain controls? I want to be able to push the pre into slight (or maybe heavy) distortion.
Thanks in advance.
Thanks in advance.
sdelsolray said:A Pendulum Audio MDP-1a has both gain and output controls, allowing you to do what you mentioned.
NL5 said:Is there a tube pre (real tube - not toob, or tewb) that has both input and output gain controls? I want to be able to push the pre into slight (or maybe heavy) distortion.
NL5 said:What is the difference between the MDP-1 and the MDP-1a?
xstatic said:I am not sure that I am aware of a tube pre that does not have both input and output controls.
xstatic said:Then I stand corrected![]()
Thanks in advance.
i'm using linking channels for bass and guiatrs with success always.With the Sebs you can take the output of one channel and run it into the di / line input of a second, third etc .... then you can drive the first channel harder and use the second to either add another gain stage or to attenuate the output of the first
xstatic said:Why cascade channels if you can just get a good preamp that allows you to do it on one channel?
Ben Logan said:So there's one reason. Put that in your hard-drive and smoke it, Chesrock!
I know, you're going to blast me with, "why are you wasting money on another cheap pre when you should be upgrading your crappy soundcard?"
Jburn34 said:You can get a Shure inline pad to solve that problem.
