Is it possble???
  • Thread starter Thread starter CLos
No. Not in the true sense of what I believe you're desiring.
"The DP-01 is equipped with a MIDI OUT jack. This can be used to drive a sequencer, drum machine, etc., either synchronized to a time base, or a MIDI clock. MIDI OUT is also used to drive a MIDI instrument as a metronome". (DP-01 Manual)
There is no MIDI IN jack to accept external clocking for synchronization.
Of course, you may "link" them in the sense of mixing your entire 8 tracks into stereo, and recording it down to 2 tracks on the 2nd DP01 using the stereo Line Outs hooked to the other DP's inputs. I'm afraid that's probably not quite what you had in mind.
:spank::eek:;)
thank, oh well....thats how I thought it might have to be done. So the RCA out outs to the line inputs on the front, right? but why would it have to use 2 tracks?
You don't have to, but honestly...
this 2-Porta solution external bounce operation would be only slightly different than the internal bounce operation, i.e., (8-to-2) vs (6-to-2).
You can bounce to 1 or 2 tracks, but using 2 tracks preserves your stereo image.
:spank::eek:;)
so, you can mix 8 from one, to 2 to the other and still have 6 open. in essence making a 14 trak recording? Rather then 12 just useing one recorder?
thanks for your help, I new to the home recording world.
Yes,...
If you want to approach it that way, that's doable.
:spank::eek:;)
