X32 routing problem
  • Thread starter Thread starter FrankD77
FrankD77
FrankD77
Photographer / musician
Hope someone can help me out.
I'm using an X32 at home and a lot of rack gear. my auxes are all used for insert effects (compressor etc).
Input wise I only use input 28-32 for mics.
So I have a lot of in and outputs left on the back.
Seeing I also have mix busses left I was hoping the following.
Connect a reverb unit to input 1-2 and output 1-2
And assign these XLRs to Mixbus 1-2.
However I don't want to loose my 1-27 for USB from my DAW.
I've first tried to figure it outmyself but keep running into issues where I see the reverb unit and mixbus getting signal but no sound on the master out. Or I will lose my input 1/2 from the DAW (USB).
I've asked Ai which claims it was possible but keeps giving me information to use auxes or sacrifice in/outputs of the USB card.
I don't have a lot of experience with deep diving the X32.
If it's not possible on the X32 would it be possible on the Wing full version ?
Your 27 DAW returns plus five mics already use all 32 normal input channel strips, but that does not by itself rule out an external reverb return. The important distinction is the physical Aux I/O sockets versus the six Aux input channel strips.
If those Aux strips are not already carrying needed signals, Aux In Remap has a Local 1–2 option. That lets local XLR inputs 1/2 feed the Aux input strips without replacing Card 1/2 in the normal input block. Behringer shows the separate remap column in its routing diagram: https://www.bax-shop.nl/downloads/products/9000-0009-1589/behringer_x-dante_qsg.pdf
The complete path needs to be Bus 1/2 → physical outputs 1/2 → reverb → physical inputs 1/2 → return strips → Main L/R. A moving bus meter only confirms the send side. Keep the return strips’ sends back to Bus 1/2 off to avoid feeding the effect back into itself. Save your scene before changing the patch.
Which firmware are you using, and are Aux input strips 1/2 free, or are they also in use? A screenshot of Routing/Inputs, including Aux In Remap, would make that distinction clearer.
All auxes are in use.
I think I over thought the whole modular idea.
I was hoping to use the XLRs as an insert straight on a mixbus without losing USB tracks.
Understood. The route I described needs two spare Aux return strips, so it won't fit if those strips are already in use too. That was a send/return path, not a way to turn an unused XLR pair into a direct mixbus insert.
Could you show the bus's Config/Insert page and Routing/Inputs? That would let us distinguish occupied physical Aux sockets from occupied Aux mixer strips. I can't confirm a direct XLR insert route that preserves your existing USB returns from the information here.
Already found out it's not possible on the x32 without sacrificing some of the USB tracks.
The wing has some more flexibility and I was already considering that step ;)
