			dastrick
huh???
Good job, arcadeko.
			Almost every interface will have the standard 1/4" instrument jack as well as an XLR 3-pin mic jack
Is there any reason you want to record the midi also? the midi is just the keystrokes on the keyboard - no sound - but you can apply that to different synths via midi. You could actually record just the midi into Reaper and use a free VST synth to reproducs the sound - then you wouldn't even need an interface because you wouldn't actually need to record an audio signal - just the midi data.
			arcadeko,
Thanks for clarifying things for me, I really appreciate it.
Yes, I did notice that in the pictures. Does that mean, in order to get stereo audio from my keyboard, I could connect the left channel to the 1/4" input, and the right channel to the XLR 3-in input (with an adapter)?
This is something I'm not familiar with, so I'm going to give it a try. I was planning on recording MIDI, send it to my keyboard which then sends it back to my computer in stereo and record that way. In regards to VST synths, I do have Reason 2.5 that I'm planning to use as well. Is that the sort of VST synth sounds that you mean?
Thanks again!
			I'm a classic newbie (have guitar, vox & about to buy digital multitracker - probably ZOOM R8). About to post a question but read your article first. You describe overdubbing, but surely this makes balancing (say vocal over pre-recorded guitar track) into the new combined track impossible other than by trial & error? So here's my original question. If I record several guitar tracks & a vocal track onto separate tracks I then need to mix them. But they won't all start at the same time! e.g. backing guitar first, then vocals enter after a few bars. How do I get them "synchronised?" Does the computer software handle this automatically?
 so please bear with me.  I think I understand everything you've posted above.  I'm using a simple BOSS BR-532 Digital that I can navigate pretty well.  Can you tell me (in caveman speak...lol) what the cable is called that connects my 4-track to my computer?   It looks like a mini-phone chord jack. Thank you so much.
			I am a BRAND-newbie, and a girl,so please bear with me. I think I understand everything you've posted above. I'm using a simple BOSS BR-532 Digital that I can navigate pretty well. Can you tell me (in caveman speak...lol) what the cable is called that connects my 4-track to my computer? It looks like a mini-phone chord jack. Thank you so much.
			Ok, thanks for the information. Is there any other equipment that I can use besides a CD burner?
			- Am I right in thinking that I really need to take the desk output (2 channels) to a digital interface and then from there to USB/FW connection on the G4?
			Thanks for this thread. In the past, I've tried to get started with this but had problems and was too busy to figure it out.
I went into my closet and brushed off the dust to my M-Audio 410 Firewire. I also have a midiman uno connection with a USB to computer and two midi (in and out) I downloaded the driver to my laptop (Windows vista 64 Bit). Everytime I plug it in it starts searching for the driver and then says can't locate it. I already downloaded it and even did an uninstall and reinstall a couple of times. M. Audio control panel is located in the lower right hand corner and all the files are there.
I then tried it on my computer with Windows XP 32 bit. Samething. Then realized that the cable might have it's own driver and it did. So I downloaded it that. Similar problem, everytime I connect it to the computer, it says searching for the midiman uno driver.
Went back to vista to download the uno driver and it says that it doesn't need a driver in Vista.
Neither one is working. I never used the firewire or the cable but they are about 3 or 4 years old.
What can i do to get this setup?
Thanks
David
