mjbphotos
Moderator
Giving a new set up to my (admittedly cheap) Epiphone Dot Studio, all the strings/frets are true except the G string. I have thee adjustable bridge nut pushed as far out as it will go, but the played notes are still sharp - it's the only string that is a problem. The adjustment screws are facing the neck, would swapping the whole bridge around (so the adjustment screws are facing the tailpiece be better (or make a difference)? The bridge position is not adjustable as far as I can tell (up and down yes, back and forth no).
Any quick solution ideas?
As it is, if I tune the guitar with the G string open, when I play that string anywhere on the neck it rings noticeably sharp, and if I tune to the frets, the open G sounds flat.
