Thanks for your suggestion, I gave it a try and still get a final mix flat and everything centered, I have tried storing my mix in the scene memory and bringing it up when I do the int mixdown then shutting off scene sequence, I have also tried it with scene sequence on, the whole time it is saving the mix it is showing my mix name on the display and everything sounds great, when it is finished I play it back and it is as if I never mixed it at all, I've tried everything I can think of and I am about to give up trying to do it this way, I may just run a cable to my stereo or PC and burn the songs over there because wasting hours mixing and re-mixing just to burn one song is time I can not afford to be wasting, and I have 6 songs to do this with!
I don't understand why it has to be so difficult to use the internal CD burner, especially when everything is showing and sounding the way it is supposed to until I listen to what is supposed to be a saved final version of my mix which so far just turns out to be a save of everything before any mixing has been applied at all.
Any other ideas?
