Scottgman
Legend in Own Mind
I ordered some Bill Lawrence humbuckers. I've heard people rave about these PuPs (both on this board and elsewhere) so I ordered some to replace the EMGs I can't stand anymore.
Anyway, I'm no electronics geek but over my 16 years of playing guitar, I've replaced the PuPs in every guitar I've owned and never had a problem.
So now I'm having a problem... heh. I bought brand new tone and volume pots and followed the wiring diagram. I am very confident I have everything wired correctly and I am pretty sure I have good solder connections. The PuPs work but the neck volume pot is scratchy and will cutout if I'm rolling the volume off and on. The tone pot is also scratchy and seems to be interacting with the intermittent sound (if that makes sense). Basically the neck volume and tone pots aren't acting right.
Also, when I switch between the PuPs there is a noticeable "click." The Bridge pickup, volume, and tone pots are all working properly.
I re-soldered the connections to the neck PuP volume and tone pots thinking I must have a bad connection (since the bridge PuP works fine) but that didn't help. I guess my problem is I'm not good at troubleshooting electronics. I'm not sure if this problem is just a bad connection on a ground, or if the pickup selector switch is bad, or if the volume and/or tone pots are bad (brand new?), or if the pickup is bad (brand new and Bill Lawrence tested?).
I did use kind of a hodge-podge of spare wires to create my ground loop so I'm thinking about rewiring the whole guitar. I'm also thinking about replacing the pickup selector switch just to make sure.
However, I was hoping someone would say: "Dude, that's definitely a ground problem, re-solder your grounds and you will be good to go."
If you can provide that answer, you've made a friend for life. Otherwise, any advice or suggestions to troubleshoot this SOB would be sweet.
Cheers!
Cheers!
