I mean, I'm comfortable to use it, but if you mean if I am comfortable in understanding it, I am not. I would need to know how to plug it into the deck and what settings to turn it too. That's all. And to back track, I got the 18kHz tone EQ setting to work. The manual states that, as long as I have set that frequency the closet to 0VU, that's the most I can do. All the channels are either on 0vu or hovering just below/above it.
I downloaded a freeware oscilloscope, just to see my signals thru the machine when running the MRL tape. They all appeared to be equal.
Just as well, all my inputs/outputs are a lot more equal-leveled now. I played back a tape I previously recorded on, pre-calibration, and, believe it or not, it sounds brighter and less noisy. I attribute the brightness to the demag, but the noise?? I
assume the calibration made a difference. All around it sounds "cleaner", if you will, so to my own ears, it sounds like the calibration helped it out a lot.
Now whether or not it is correct on paper, that I'm not sure of.
I would like to try the VOM out, I just don't know what to set it too and where to plug the cables into on the in/out channels.
But also, I'm trying to get MRL for my 2 track, just to have that ready for that deck. This is what I am looking at:
http://usrecordingmedia.com/mrltwosp1mrl.html ... is this a correct choice for my Otari deck?
Let me know, thanks.
