R
richardosim78
hi ,
im into home recording, composing music, playing guitar, a bit of singing, midi stuff etc...
ive got a question:
if the small mic mixer has 8 jack/mono inputs (with level control on each) and specs say that device has 600 ohms inputS (plural!!!) and 1500ohms outputS..
(device is called stereo, but in fact all inputs r just mono holes. 2 groups of 4mono holes=total eight simple mono holes)
Soundlab G105DA MicroMixer | Laenenmusic.nl
http://www.amazon.co.uk/G105DA-Soundlab-Channel-Stereo-Microphone/dp/B0048FBBS8
1. so, does each of the inputs have 600 ohms, or its a total impedance of all connected sources/sum???
2. what kind of sources, instruments, mics can be used with it?? opinions on any usage, configurations, interesting useful applications, signal splitting, stereo panning/splitting?
3. as i understand, sources like electroacoustic guitars with much higher impedance cannot be used with this quite low impedance mixer??
4. if the signal is that low, that means this device needs lots of level gain increase and probably will generate quite noticeable hum/noise??
thankss
good day!
ive got a question:
thankss
good day!
but i dont regret... and never will...
