Identify this German shotgun mic
  • Thread starter Thread starter evilmonkey666
E
evilmonkey666
Hello, I recently salvaged this shotgun mic and am trying to find some information on it. The only identifying text on it is where it says: “MADE IN GERMANY” around the base of the handle. Other than that there is no model number or manufacturer info anywhere to be found. There is a switch which reads: “AUS” and “EIN B.TEST” (On-Off?) and a three way switch labelled: I-II-III (bass roll-off perhaps?). Any info is greatly appreciated.
That's a rare shezhlsmer It's worth millions!!! Almost a one of a kind.
lol, your first post had my hopes up. Thanks for the bump at least :P
Sometimes you have to open the microphone up to see who the manufacture was samr for the model name.
I got a so called no name microphone out of a store for cheap once and when I got out side I unscrewed it to find out it was a Sennheiser SDC.
Wait till John Willett gets a gander at it, he will probably know what it is.
Of course I do ;) - I actually answered this same question yesterday in another forum.
It's a Sennheiser K 3U (or K 30AV) with an ME 88 long-gun capsule with the supplied foam windshield missing.
The K 3U has an XLR, the K 30AV has an 8-pin Tuchel and is unbalanced (the K 30AV was designed for on-camera use).
When you switch the mic. on the red light flashes brightly to show the power is good - if it flashes dim or not at all, change the battery.
The K 3U can also be phantom powered.
The I/II/III switch is bass roll-off.
K 3U owners manual (PDF) is HERE.
ME 88 owners manual (PDF) is HERE.
I hope this answers you OK.
Awesome, thanks for the info. I followed moresound's advice and found I could unscrew the capsule. Once open I could see the sticker in the battery compartment identifying it as a Sennheiser K3-U. I just checked inside the capsule where it screws on and it is indeed an ME-88. Thanks for the links too. Cheers!
Why are they called "shotgun" mics, when they function more like a RIFLE?
A short gun mic. is normally called a gun mic. or shotgun mic. (eg: MKH 416 or MKH 8060)
A long gun mic. is normally called a rifle mic. (eg: MKH 816 or MKH 8070)
