Ibanez TS- Tubescreamer Vs Boss SO-1
  • Thread starter Thread starter Locking Nut
L
Locking Nut
Which do you guys think is best/prefer out of the TS-9 tubescreamer and the Boss superoverdrive?
I already have a distortion pedal so I want just a nice overdrive pedal to go with it or to go infront of my amps distortion to give a solo boost/tone enhancer. And to give a clean boost when I have the distortion off.
The OS-1 is half the price so I am tempted to go with that but if the Tubescreamer is as good as it's supposed to be I may splash out the extra dosh for that instead.
I have a Marshall AVT btw.
I'm not sure this is the right forum....but personally I'd go with the Boss SD-1, cheap, reliable and great sounding.
Is the AVT a tube amp? I thought it was solid state.
Tube screamer is my fav. It just sounds like butter
tube screamers have a mid-range hump that I loathe....however, it is the most cloned pedal of all time, and a visit to musictoyz.com should introduce you to some nice alternatives.
Also, check out www.robertkeeley.com. I cannot recommend his work more.
The reason I've chosen these two pedals is because there is only one shop round here that sells much of a selection of pedals and they have nearly all boss with the odd one of something else. They have these 2, and they are very popular so that's why I got it down to these. There may be many alternatives, some may be much better, but if I can't play one first I don't wanna take the risk.
p.s. The AVT is a hybrid amp, valve pre-amp and SS power amp.
Then the choice is simple, try both out, buy the one you like best.
IMO the TS 10
puts the 9 to shame.
havent tried the boss...
I've bought the SD-1 for £40.
When you use these Boss pedals do you have to use the Boss adapters or can you use another? I know if you don't use the Boss one and sommat goes wrong your warranty is no good but is it just a recommendation to use theirs?
you don't "have to" but the alternatives aren't that much cheaper anyway
I've always got some mains adapters knocking about the house.
