R
Rock Star 87
ok, i posted about this a couple months ago, but i didn't really know what i was talking about, so here's the scoop because the problem still remains.
I am using an SBPCI card and all my MIDI work is done on the internal synth. i can choose between that or a MIDI mapper, but i for one, don't know what the MIDI mapper is, and two, they both have this problem. My one MIDI track is turned to 64 on my console. Whenever i play the piano line it sounds fine, but when i burned to cd i found out when the treble is turned up the whole way, there is this miserable hissing. then i found out that this also happens when playing the MIDI track. i found this out while turning the treble up all the way on my soundcard. but one weird fact is that after i stop playback the static still remains. when i go to options>MIDI devices it stops until i play the track again. earlier today i somehow recorded it and it sounded like i wanted it to, but i don't remember how and reloading the file and rerecording yields hiss.
let me know if u need more info. if i don't fix this, i can't ever use MIDI. pleeeeze, for the love of god help me.
i usually set it to 64 on the console but i get the same result with 127. on my reocrding meter on my empty audio track b4 i'm getting ready to record there is about -72 dB's of ??? going. when i set the output mix to record, and have everything but the synth muted out, it stays. when i mute the synth, it goes away. i don't think there should be any interference in the synth.
Want better headroom? Get something runs 24 bit (assuming you use decent cables & routing)
